Any simple methods for measuring bike wheel cadence using wires and not bluetooth or ANT+ etc?
Hi everyone,
I am doing an exercise study and need to measure bicycke cadence... In the event I am unable to tap into the bike electronics and access the raw data signals, would any have any suggestions for how I caouls measure cadence using a bike cadence magnet or other simple device?... My LabvIew system and DAQ is aging and a wireless set-up will not likely work... Any suggestions would be greatly appreciated..
Thanks!
(2,551 Views)
You could use an encoder attached to the axle, but the main issue will be supplying power to an NI DAQ device attached to a moving bicycle in a robust manner. What kind of environment will you be testing in?
Conner A.
Technical Support Engineer
(2,521 Views)
A simple data aquisition is a sound recorder. ('smart'phone or dedicated device)
lowest frequency is in the 20Hz range
Assuming that the wheel spokes at the wheel rim are sufficiently equal spaced a gitarre pick up (or alike) with that sound recorder will do the job. every spoke will give a pulse
The filling valve will give you an absolute index 😄
KISS
Or use an incremental encoder rigth at the axis for a higher resolution (and frequency)
And than we use LabVIEW to analyse the data 😉
Greetings from Germany
Henrik
LV since v3.1
(2,512 Views)
A build in powerful encoder could be an axle dynamo 😄
Henrik
LV since v3.1
(2,510 Views)
