Any way to run a cDAQ-9171 with LV 8.2?
I tried the tricks listed for LV 8.5, but they don't work with 8.2...
- If there is no way to run with LV 8.2, is 8.5 the lowest version that will operate the cDAQ-9171? (using the 9.3/9.5 partial install trick...?)
- Assuming that is the case, is there an inexpensive way to upgrade 8.2 to 8.5?
I am a hobbyist and can't afford the latest and greatest; what are some of my upgrade options?
Jim
(3,155 Views)
Unfortunately, I don't think so. The latest driver supported by 8.2 still does not support the 9171. Upgrading from 8.2 to 8.5 will not be possible because 8.5 cannot even be purchased any longer.
If all you need is personal access to the software, you may be interested in this one. Smiley Happy
https://www.ni.com/en/shop/labview/select-edition/labview-community-edition.html
http://store.digilentinc.com/labview-home-bundle/
Hope it helps.
Camilo V.
(3,116 Views)
Thanks, Camilo, that is EXACTLY what I need...
(3,106 Views)
