NI PCI 5105 Resolution behaviour
I am using a PCI 5105 to acquire AC signals that correspond to currents. The acquisition is within ±15V (30 volts) range at 60MHz. Thus, the resolution I'm working with is 30/4096 = 7.32mV, as the 5105 has 12 bits of resolution. Searching the forum, I found that the actual resolution is a little bit higher than this value, around 9mV, which is not really a problem.
The problem is that this value means a significant amount of current, so what I need to know is what happens between two LSB's. What I mean is: when the signal is, for example, 6mV above the last bit that is set to 1, does the output holds the previous value or it has a chance of setting the next bit to 1? Also, if my signal is decreasing, and it decreases 4 or 5mV, the mostright bit is set to 0 or it stays at 1 until the signal decreases the 9mV step?
In short, if a input signal increases less than the resolution step, what happens at the output? And what happens when it's decreasing?
PS: I can't work with a lower voltage range or sampling frequency, so decreasing the step is not an option.
Thanks in advance,
Miguel.
(3,134 Views)
Accepted by topic author MiguelNeto
Like you yourself have calculated, the code width (range/2^resolution) is the smallest value change that the device can detect. If device has a range from -10 to 10 and the resolution is 12 bits, so the code widht is 2.4mV. Changes below this values is not detected by ADC.
Calculating the Smallest Detectable Change—Code Width
https://www.ni.com/docs/en-US/bundle/ni-daqmx/page/codewidth.html
If you need more steps, you should use a higher resolution device.
At below link there were others PXI/PCI scope options:
https://www.ni.com/en-us/shop/category/oscilloscopes-and-digitizers.html
Lincoln
(3,048 Views)
