App. builder error
Has any one had any problems using the MxBASE VI when trying to use the app. builder?
(3,061 Views)
There are a couple of known issues.  Have you seen these KBs? [broken links removed]
NI-DAQmx Base Program Does Not Work as an Executable
Application Builder Hangs/Crashes when Trying to Build a DAQmx Base VI into an Application
I would suggest taking a look at those.  If that doesn't solve your problem, just re-postSmiley Happy
-Alan A.
(3,042 Views)
