Home
Community
Discussion Forums
Most Active Hardware Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
App. builder error
App. builder error
AW comp.
Member
07-05-2005
02:15 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Has any one had any problems using the MxBASE VI when trying to use the app. builder?
0
Kudos
Message
1
of 2
(3,053 Views)
Reply
Re: App. builder error
AlanArmstead
NI Employee (retired)
07-06-2005
03:11 PM
- last edited on
03-06-2026
09:40 AM
by
Content Cleaner
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
There are a couple of known issues. Have you seen these KBs? [broken links removed]
NI-DAQmx Base Program Does Not Work as an Executable
Application Builder Hangs/Crashes when Trying to Build a DAQmx Base VI into an Application
I would suggest taking a look at those. If that doesn't solve your problem, just re-post
-Alan A.
0
Kudos
Message
2
of 2
(3,034 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
