Are there any quality DSUB-BNC breakout boxes compatible with the C series modules?
Are there any quality DSUB-BNC breakout boxes compatible with the C series modules? I.e. something like BNC-2110, but compatible with the DSUB-25 or DSUB-37, so, I would be able to connect NI-9201, NI-9401,  NI-9403 and so on. I can't find anything suitable.
Thanks and regards,
Dmytro
(898 Views)
See C Series with D-Sub Terminal: I/O Cable & Accessory Guide
https://tmesystems.net/
(878 Views)
Hi ZYOng, thanks for sharing, I have never seen this document before. Unfortunately the only options for my case are NI-9923 or NI-9924, but I do not like them (I have NI-9924 in use right now), because it is hard to organise the wires properly.
Sorry if I was not clear, but I am looking for something like https://www.koax24.de/en/product-info/breakout-box/bnc-on-d-sub.html
(872 Views)
You can either use a Front Mount Terminal Block or cable + DIN Rail Mount Terminal Block. The latter is analogous to the BNC terminal block.
For example for NI-9201, you can either use NI-9924 or SH25F-25M + 781081-01.
(863 Views)
Thank you. Will scratch my head and try to tinker something out of what is available.
(851 Views)
