Are there any unit test framework tools for DAQmx programmers that use the C interface?
I need to accuratly simulate DAQmx devices for unit testing the software being developed. Are there any tools available to make this easier?
(3,484 Views)
Accepted by Chris_c++
You have the built-in simulation of DAQ devices in MAX. The simulation is limited. It is explained in the NI-DAQmx Help (NI-DAQmx Key Concepts>NI-DAQmx Simulated Devices).
(3,482 Views)
Good solution. Thank you.
(3,470 Views)
Can a simulated device be created programmatically?
(3,461 Views)
