Assign cursor position to xy graph
Hi All,
I am working on an application for an electronic throttle test stand. I have a force-displacement plot that I have assigned cursors based on the position only of the data. There are two points that I will need to find the position based on the force applied. The data has a large spike that I will need to find the point just before the spike. I am attempting to attach my VI and text data. I hope this comes over. I really need help with this. I understand that this can be accomplished with math however, I learning Labview and see multiple VI's for derivates and thresholds. I would like some input.
Thanks Warlenia
(2,862 Views)
Hi Warlenia,
Please repost your question to the LabVIEW forums.  I believe you will receive a much better response there.
David_B
(2,834 Views)
