PCI-6251, Analog output trigger with the other analog output available
Dear friends,
I want to do phase locked PIV measurements. to do that with a frequency generator and with 2 triggering device.. this is possible ... but there is a small problem with availability of both the triggering devices at once. for this reson i want to write a small code in labview which can give me a trigger.
I have modified the frequency generator example(inbuilt) of Labview but i am not able to trigger the other analog output channel with this frequency generator (analog output).
I can generate, simultaniously, different waveform at different chennal, but I am not able to seprate them..  I think this is a bit confusing (even for me to explain..)
may be the attached block diagram will help to explain this batter..
image link http://img2.freeimagehosting.net/image.php?7bcbc3c831.jpg
Thus
1) I should generate a contineous signal with certain frequency and amplitude (No problem with this) in AO-0
2) Gives trigger at '0' crossing + phase shift  (unable to trigger AO-1 with AO-0)
3) should wait for 100ms (laser property)
4) search and give second trigger at next '0' level crossing (of signal) + phase shift
Please help me with this. And if there any example i can refer please suggest me.. I searched through the labview example but nothing is clear for me..
And as you might have guessed I am new with labview.. I am using Labview 8.2 and PCI-6251
Thanks in advance
(2,800 Views)
Hallo,
Is there any one who can help me with this??
i need some help as i can't able to do this myself 😞
(2,730 Views)
