Attempted writing analog data that is too large or too small -->USB6009
I'm using the attached example in VC++ to write voltages by a USB-6009 Using the function DAQmxWriteAnalogF64 . I get an error -200561 ("Attempted writing analog data that is too large or too small") occurs when I'm writing voltages with the analog out range set to 0 .. 5 Volt.
Parikshit
************************* code***************************************
#include <stdio.h>
#include <math.h>
#include <NIDAQmx.h>
#if defined(WIN32) || defined(_WIN32)
#include <windows.h>
#endif
#define DAQmxErrChk(functionCall) if( DAQmxFailed(error=(functionCall)) ) goto Error; else
#define PI 3.1415926535
int main(void)
 int         error=0;
 TaskHandle  taskHandle=0;
 float64     data[1000];
 char        errBuff[2048]={'\0'};
 uInt32      i=0;
 for(;i<1000;i++)
  data[i] = 9.95*sin((double)i*2.0*PI/1000.0);
 i = 0;
 // DAQmx Configure Code
 DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
 DAQmxErrChk (DAQmxCreateAOVoltageChan(taskHandle,"Dev1/ao0","",0.0,5.0,DAQmx_Val_Volts,NULL));
 // DAQmx Start Code
 DAQmxErrChk (DAQmxStartTask(taskHandle));
 printf("Generating samples continuously. Press Ctrl+C to interrupt\n");
 while( 1 ) {
   Sleep(1);
  #else
   #error - This example requires a platform specific sleep call.
   // This example requires a platform specific sleep call.
   // For example:
   // #include <windows.h>
   // Sleep(1);  // For Windows platform
   // #include <unistd.h>
   // usleep(1000); // For Linux platform
  #endif
  // DAQmx Write Code
  DAQmxErrChk (DAQmxWriteAnalogScalarF64(taskHandle,1,10.0,data[i],NULL));
  if( ++i>=1000 )
   i = 0;
Error:
 if( DAQmxFailed(error) )
  DAQmxGetExtendedErrorInfo(errBuff,2048);
 if( taskHandle!=0 ) {
  // DAQmx Stop Code
  DAQmxStopTask(taskHandle);
  DAQmxClearTask(taskHandle);
  printf("DAQmx Error: %s\n",errBuff);
 printf("End of program, press Enter key to quit\n");
 getchar();
 return 0;
(5,341 Views)
Hi Parikshit,
According to the equation in your code, 9.95*sin((double)i*2.0*PI/1000.0), your sine wave will have an amplitude of 9.95 V and thus will output at a range of +/-9.95 V.  This is outside your analog out range of 0 to 5 Volts.  Try the range -10 to 10 volts and see if you get the same error.
I hope this helps!
- Erik
(5,296 Views)
I tried changing the  values of data from 9.95 and tested between -10 to +10 but the error remained which u can see in the attached image
 data[i] = 10.0*sin((double)i*2.0*PI/1000.0)
(5,285 Views)
I have managed to remove the error by slightly modifying the code so that reading's dont go into the negative zone but even though the program works fine the output is not generated on the voltmeter.I know the problem is in the program bcoz the program in VB works fine.
here is my modified  code please help.
#include <stdio.h>
#include <math.h>
#endif
int main(void)
 int         error=0;
 float64     data[1000];
 uInt32      i=0;
 i = 0;
 DAQmxErrChk (DAQmxCreateAOVoltageChan(taskHandle,"Dev1/ao0","",0.000000,5.000000,DAQmx_Val_Volts,NULL));
 // DAQmx Start Code
 while( 1 ) {
   Sleep(1);
  #else
   // For example:
  #endif
 for(;i<1000;i++)
  data[i] = 5.0*sin((double)i*2.0*PI/1000.0);
       if(data[i]<0)
     data[i]*=-1;
   printf("\ndata[%d]=%0.2f",i,data[i]);
   DAQmxErrChk (DAQmxWriteAnalogScalarF64(taskHandle,1,-1,data[i],NULL));
   if(i%1==0)
    getch();
  // DAQmx Write Code
  //DAQmxErrChk (DAQmxWriteAnalogScalarF64(taskHandle,1,-1,data[i],NULL));
  //if( ++i>=1000 )
  // i = 0;
Error:
  // DAQmx Stop Code
 getchar();
 return 0;
(5,277 Views)
Thank u guys now it is working fineSmiley Happy
(5,274 Views)
Great!  Let us know if you need any additional help.
Good luck with your application,
- Erik
(5,261 Views)
