Automatically Retriggered AI
I have an application where I need to have N data points aquired at rate S every time a digital trigger is detected.
For example, in one application the trigger signal will occur @ roughly 100Hz.  In this case we want 10 samples at 10Khz.
Is there a way to set this up so the acquisition gets ready to re-acquire after each acqusition, without software interaction?
(3,308 Views)
Here in this knowledgeBase document you can find your answer.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019MXxSAM&l=en-US
(3,291 Views)
