10-30-2012 03:45 PM
I have an application where I need to have N data points aquired at rate S every time a digital trigger is detected.
For example, in one application the trigger signal will occur @ roughly 100Hz. In this case we want 10 samples at 10Khz.
Is there a way to set this up so the acquisition gets ready to re-acquire after each acqusition, without software interaction?
10-31-2012
10:49 AM
- last edited on
08-21-2026
09:30 AM
by
Content Cleaner
Here in this knowledgeBase document you can find your answer.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019MXxSAM&l=en-US
