Backplane Triggering of DAQ from FPGA using Python
Hi all,
I'm attempting to create a PXI-E Chassis backplane link between an FPGA and DAQ so that i can create a digital trigger to start a sequence in the DAQ. Currently I have the following in the FPGA that will generate a 1us pulse as needed and send it down PXI0;
I am then trying to retrieve the trigger from a task written in python that controls the DAQ, I believe I have most of the commands needed for this but I am struggling to retrieve the actual signal from the backplane. When creating a task you can add digital, analogue or counter channels as inputs or outputs, e.g. task.ai_channels.add_ai_voltage_chan('device/ai0').
I presume that to add a digital trigger signal you will require task.di_channels.add.di_chan('address'), this is fine however I am struggling to find a way to actually link the trigger.
With any connector attached to the front of the DAQ it has a corresponding label matching the pinout of the device however i have not been able to find any such reference for the backplane.
- Can anybody tell me what the naming scheme for the backplane connectors are to make a direct connection? Failing this;
- Can anybody tell me how to create connections between pins as shown in NI-Max, i.e. when looking at the DAQ it shows that a connection can freely be made between the backplane and PFI channels (see below):
How do I actually make the connection between the two of them in Python? I am aware that in Labview the connection can be made, and that you can connect straight to the backplane also through labview by declaring the I/O.
The DAQ is a 6289 mounted in a PXI-e 1078 chassis,
Thanks in advance,
Paul
(2,938 Views)
You should able to use the start trigger module for the DAQmx task  (https://github.com/ni/nidaqmx-python/blob/master/nidaqmx/_task_modules/triggering/start_trigger.py) to set the start trigger for your task to PXI_Trig0.
Though I have never use DAQmx's Python API; I have only done this in C API. I imagine it should be the same entry point both API call in the end.
(2,905 Views)
