Best way of multi-channel measurements using NI-USB 6009?
I'm new to labview and I'm trying to acquire multiple voltages from several channels and display them on one graph. It seems impossible to do it simultaneously since that NI-USB 6009 has only one set of ADC.
The only way I have ever come up with is to use daq assistant to acquire voltages one by one and then make it a while loop, but is there any time delay during the shift between channels?
And is there better ways to acquire data from multi-channels?
(4,809 Views)
Accepted by topic author JudeLi
If you have specified multiple channels (i.e. Dev1/ai0:ai3) with a single DAQ Assistant, then that is the correct method. The inexpensive device does not have simultaneous inputs so you'll have to live with the small inter-channel delay.
(4,807 Views)
Thank you for your reply!
Is it something like this?
(4,797 Views)
Can you post images of the block diagram and DAQ Assistant. I'm not at a computer right now.
(4,794 Views)
(4,792 Views)
Like this?
(4,788 Views)
You didn't show the DAQ Assistant but it seems you are acquiring all channels.
Please note that you will may run into memory problems if you run the VI for a long time. How much do you really need to display?
(4,784 Views)
