Multifunction DAQ
Buffering with USB 6501
I have an event based trigger of 250 n sec. The event is random and can be occured anytime. But the duration of pulse if very short i.e. 250 n sec.
I am using NI USB 6501 to capture this trigger. Can NI USB 6501 provide buffer to capture such triggers ?
Bilal
(4,231 Views)
Bilal,
(Let's put these related question into one common post).
As I described on your other post. I don't think you are going to be able to use the USB-6501 for this application. If you post on the other discussion and answer my questions there I think I can point you in the right direction for hardware that will allow you to measure your signal.
Aaron W.
CLA, CTA and CPI
(4,229 Views)
