 LukeRutter
			LukeRutter
			06-18-2021 04:24 AM
I'm looking at using the NI9775 module in a cDAQ but so far am not having any luck getting it working with LabVIEW throwing error 209845 at me.
I'm not too sure how to resolve this and was unable to find much info on it around the web so I'm hoping someone here can advise.
Looking at the NI9775 specifically I wonder if it is actually able to work properly in a cDAQ, as all examples I can find of this module in use (including official LabVIEW examples) all use cRIO with FPGA.
Any help greatly appreciated.
 JensG69
			JensG69
		06-18-2021
		08:43 AM
 - last edited on
		08-21-2025
		03:26 PM
 by
		 Content Cleaner
			Content Cleaner
According to the NI 9775 Datasheet it is also possible to use it with DAQmx, so you should be able to run it in a cDAQ-9178 chassis.
Have you tried to run the testpanel from NI-MAX - always a good source to start with.
Regards, Jens
