‎02-20-2008 01:47 PM
‎02-21-2008 10:09 AM
‎02-21-2008 10:48 AM
Also, when you are doing your counter frequency measurement can you confirm that you are doing the 1 counter method? It as also possible to do a 2 counter method and doing this may cause the 50103 error if you are using one of the counters in another task.
‎02-21-2008 11:33 AM
Thank you for your comments. I now understand why Labview was telling me why I was using reserved resources. I was using CI freq that required two counters.
Noel
‎02-21-2008 12:27 PM
Out of curiousity why does the 2 counter methods cause this problem? If I use the angular position for Ctr0 which require inputs to PFI0 (A) PFI1(B) and PFI2(Z) and use a 2 counter method (high frequency or large range) for Ctr1 that only requires PFI3 (A) the two counter method still only requires one input so why the resource conflict.
Noel
‎02-22-2008 02:36 AM
‎02-22-2008 11:40 AM
