CRIO setting input range per channel
Most NI hardware allows you to set an expected input range (+-200mv,+-5v ,+-10) for each channel individually. What about CRIO?
To further confuse the matter the CRIO-9219 is a universal module which has a property for setting which input type should be used PER CHANNEL. Is this an input module that defys what is the "norm" in regards to CRIO modules?
Interested in hearing your response,
Craig
(3,497 Views)
Hi Craig,
Are you using, or considering using the 9219 module in a Compact DAQ chassis or a CRIO chassis?
Wallace F.
(3,479 Views)
I'm considering the 9219 and the 9205 for the CRIO. I found my answer...although not in the datasheet or specifications (atleast that I could find). The overview for the 9205 speaks that range is set per channel. (which is great!). The 9219 states similarly that each channel is individually selectable within the overview section. So my question has been answered.
Craig
PS. Kudos to Maria (sales) and Nick (CRIO) for the help in locating this information!
Message Edited by craige on 10-09-2008 08:28 AM
(3,466 Views)
