Are you able to test this exact project in a different version of CVI? Did this program immediately stop working once you installed 8.1 or did it work for a while?as I said in my message it works on all previous versions of CVI....so yes to your question.
Also, I'm going to need more information about your code - for instance, does the GPF occur every time ProcessSystemEvents(no) is called or only after the EVENT_CLOSE event has been fired? Yes. it seems to be random and only seen on one PC. If you left the code run and did not touch the hot key it was fine. It does not happen everytime.
One other thing to consider - the GPF may actually be queued in your system and my not be occuring at ProcessSystemEvents; rather, you may just be seeing it there because the system queue is processed then. Is there any other time that this error may have occurred?
hard to say..but not seen so far.
- Make Software User Friendly -
