Can I acquire waveform at faster sampling rate using external clock?
I am trying to acquire waveform at a sampling rate of 1MHz. My 6036E card is maxed out at 200KHz. Is there a way to achieve a sampling rate of 1MHz using an external sample clock? Your PFI pin can take external clock as an AI sample clock, right?
(2,814 Views)
I remember I asked the similar question before in the NI forum, they reply me:
the max sample rate (scan/s/channel) cannot be greater than your board max sample rate, even you use external scan clcok. So the answer is no for your case.
(2,805 Views)
