How can I use a GPIB and AT-MIO-16L with a common NI-DAQ?
I'm using a GPIB card for recording data and a AT-MIO-16L for sending an analog output to my instrument. Earlier, both the devices (GPIB and AT-MIO-16L) were running correctly. Until I reformated my hard disk. Now I'm trying to install NI-DAQ 6.1.1 for AT-MIO-16L but that doesn't detect my GPIB card. On the other hand if I use NI 488.2 along with MAX 1.7 or MAX 2.2, I'm unable to use AT-MIO-16L. Is there a way I could get both my devices running on a common platform?
(2,528 Views)
NI-DAQ is not supposed to detect your GPIB and NI-488 software will not detect your daq board. When you installed MAX, was this from a LabVIEW driver install CD that also put a new version of NI-DAQ on your pc. Open MAX and check your currently installed versions of NI-DAQ and NI-488. They should both be listed. If you have a new version of NI-DAQ than 6.1, you can uninstall the newer version and install 6.1.
(2,517 Views)
