09-07-2008 09:25 AM
Hi..
Im doing a Heater Control system project need to interface my RTD to my NI 6040E card or should i use a wheatstone bridge to do to convert it to Voltage and then only connect my NI card to it ..
09-08-2008 04:52 PM - edited 09-08-2008 04:55 PM
Hi Barath,
Thanks for posting on the NI Discussion Forums! You can take RTD measurements with your 6040E, however you need to provide your own external excitation. In Measurement & Automation Explorer (MAX), you can create an RTD task by right-clicking Data Neighborhood and selecting Create Task. Take a look at the image below.
You will choose your device, and then configure the task in the window below.
Take a look at the following developer zone article for more information and let me know if you have further questions.
NI Developer Zone Tutorial: Temperature Measurement with a Thermocouple or RTD
09-09-2008 12:28 PM
ThankYou i knew you should use the max window and setup RTD just wanted to be sure..
thank you very much
