Multifunction DAQ
Can I connect a TBX-68T to a SCXI-1000
I am using a TBX-68T connected to a NI 4351 PCI.
Now I like to connect a SCXI 1000 chassis to the 4351-Card but use the TBX-68T aswell.
So my question is: Can I connect the TBX-68T to the chassis?
I got a SCXI 1180 Feedthrough Panel, but I dont know how to connect them, as they got different plugs.
This is my first posting here, so i hope I hit the right borad.
Thank you very much for helping me!
(2,998 Views)
there’s no direct way to connect a SCXI 1180 feed through module to a TBX 68 T connector block, because the SCXI 1180 feed through module has 50 pins and the TBX 68 T connector block has 68 pins. If you want to use the SCXI technology, you can use a NI SCXI-1102 32-Channel Thermocouple Input Module in combination with a SCXI-1303 terminal block.
Hope this helps!
Ulrich
Application engineer
NICER
(2,983 Views)
