Can I get a real-time display using waveform chart in scope mode?
I am using a USB 6009 to display and collect data over a 10 second period at 100 S/sec. At the end of 10 seconds I get the display.  Is it possible to collect one data point at a time every 10 msec and then send that point to a waveform chart in scope mode that APPENDS the data to the last measurement so that it behaves just like a realtime oscilloscope with the trace slowly moving from left to right?  I am hoping that someone knows if is works that way before I try to build the vi.
(2,828 Views)
There is a way to make a Scope Chart. The link below should be able to get you started.
http://zone.ni.com/reference/en-XX/help/371361J-01/lvprop/wfmchrt_updt_mode/
Carl W.
Applications Engineering
(2,795 Views)
