Digital-Task-Error USB-6009
I use a NI-USB-6009 with NI-DAQ 9.7, Dasylab 12.00.01, and WIN 7. I´ll use 4 dif. AI, 4 DI and 4 DO. If I start Dasylab, there is a error: digt. task not found.
Do you have any idea ?
(3,527 Views)
Hi Hollu,
Did you create a task in NI's Measurement & Automation Explorer?
If not here is a Knowledge Base desribing how to create multiple AI tasks.
If you did and the task till can't be found I would try the DAQmx driver 9.6.1. This version is mentioned to work with DASYLab 12 on www.dasylab.com.
I'm sorry I can't offer you much help. We do not support DASYLab any more.
Kind regards
Heinz
(3,496 Views)
(3,492 Views)
How are the DI and DO tasks configured? I think that they need to be 1 sample on demand, with only the AI using the hardware timing.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(3,469 Views)
