Can I use a BNC or banana jack panelette with the SC-2345 connector block?
I am looking to use an accelerometer and have a PCI-6221 and SC-2345 connector block.  I am going to purchase the SCC-ACC01 accelerometer signal conditioning module.  However, I have run into a problem connecting the BNC cable from the accelerometer to the SCC-ACC01.  The SC-2345 I have is the connector block block, not the configurable model that has panelette options.  I am wondering if I can purchase a BNC or Banana jack panelette and wire it to the SCC-ACC01.  The panelette would be "free floating" and not part of the SC-2345.
(2,963 Views)
I'm not an EE, but the back of the BNC panelette is probably just wires you would need to solder to.  Why not just strip an existing BNC cable (you'll need the correct gender, of course) and just wire the center to the "+" and the shield to the "-".
-gaving
(2,954 Views)
