compaq daq encoder and analog sync
Compaq DAQ chassis 9174
Analog module 9234
Digital module 9421
Goal : Synchronize the acquisition of 2 analog inputs and a quadrature encoder.
Is it possible with this material?
Is the vi attached suppose to achieve this?
(3,385 Views)
I haven't done a lot with CDAQ and can't speak with confidence about the capabilities / limitations of
your particular chassis and modules.
However, the example code you posted appears to be the right approach in principle.  You've configured both
the AI and Encoder tasks to use the AI sample clock, you've correctly sequenced the calls so that the Encoder
task is started *before* the AI task (thus ensuring that both tasks see the first sample clock edge), and you're
reading a specified and equal # of samples from each task in your loop to keep your data chunks sync'ed as
well.
I can tell you you're on the right track, I just don't know for sure whether your train (CDAQ hw) works.
-Kevin P
(3,372 Views)
I have looked into the hardware, and I believe should all work also.
Jensen
(3,361 Views)
