Can I use a PXI-6224 with SCB-68 to take measurements from 4-wire RTDs or do I need a separate current source?
I suspect I already know the answer to this question:
I have a PXI-6224 M-series DAQ card and a SCB-68 terminal block and want to take measurements using a bunch of 4-wire RTDs. Is the 6224 able to source the current for these measurements, or is this not possible with the equipment I have?
I know that NI offers other solutions for my problem: I am interested in identifying whether I can do these measurements with the apparatus I currently have on hand.
Thanks!
Jeffrey Zola
(3,401 Views)
Accepted by Jeffrey_Zola
Hello Jeffrey,
You have a couple of options here, but it does look like you will need some more hardware.
The PXIe-4357 has the signal conditioning built in, but it will not work on the curent chassis you have:
https://www.ni.com/en-us/shop/model/pxie-4357.html
We also have a cDAQ option with the NI 9217, but again this gets you into a different platform:
https://www.ni.com/en-us/shop/model/ni-9217.html
We used to have an option that we do not sell anymore - the SC-2042RTD.
You can also use these two items in conjunction with eachother along with your current PXI card :
https://www.ni.com/en-us/support/model.scc-rtd.html
Lastly, you could get a SCXI chassis and drop one of these in it:
https://www.ni.com/en-us/support/model.scxi-1102.html
Thank you,
Joel C
(3,386 Views)
Thanks, Joel. As I said in my original post, I suspected that was the answer.
I actually have terminal blocks and cabling on order that will enable me to use the existing PXI-4071 DMM and the PXI-2530 matrix/MUX modules in our PXI chassis and will purchase a PXI-4141 SMU for these types of measurements- and many other applications. But I was hoping to get a head start on a project while waiting for that hardware to arrive.
Jeff
Jeffrey Zola
(3,380 Views)
