Can I use a "calibrator output" of 5 Volts to adjust the analog inputs of a 6221 OEM?
Hello everyone,
Do you know if I can use a "calibrator output" of 5 Volts to adjust the analog inputs of a 6221 OEM?
The calibration procedure is not very specific regarding this. It kind of mentions the calibrator output could be 7.5 Volts. However, in my custom board I have an analog mux with a limit of 5 Volts, and I'd like to calibrate through the whole path that includes this analog mux. Then, it would be great if I could use 5 Volts as a calibrator output.
Thank you,
Hector
(3,118 Views)
According to the calibration documentation, here, the calibrator output voltage should be 7.5V. 5V should be used for 6115/6120 cards.
(3,092 Views)
