Can I use both analog outputs on a PCI 6031E card to voltage ramp at different clock rates"
Thank you for posting to the NI Forums! Our cards only have one timing enginer, so you can only have one clock rate at a time. However, you can have two different timing channels from the 2 counters on the card, but they will share the same timebase. Hope this helps!
Message Edited by Margaret F. on 03-11-2009 02:46 PM
Margaret Barrett
Digital Multimeters and LCR Meters
(3,079 Views)
