Can I use cDAQ-9185 NI-CompactDAQ-Chassis instead cDAQ-9184?
Can someone please help me...On End Of Line tester I'm currently using cDAQ-9184 NI-CompactDAQ-Chassis for vibration measurement and connected ICP accelerometer. Current one has failure and on stock I have only cDAQ-9185.
Can I use cDAQ-9185 instead of  cDAQ-9184?
Thank you in advance
Message 1 of 8
(3,384 Views)
Hello!
The main difference is that the cDAQ-9185 only supports DAQmx driver version 17.1 and newer, while the cDAQ-9184 uses NI-DAQmx 9.6 and newer.
DAQmx 17.1 only supports versions 2014, 2015, 2016, and 2017 of LabVIEW, but the C series modules should still be supported. View the Readme to see all of the supported devices and programming environments.
Some useful links:
DAQmx 17.1 Readme
cDAQ-9185 Manual
cDAQ-9184 Manual
Hope this is helpful!
Message 2 of 8
(3,345 Views)
Thank you very much for your quick support!
I have C module NI9234 and I can see that is compatible with cDAQ-9185, but we use LabVIEW 2011.
That means I cannot use this chassis???
Message 3 of 8
(3,300 Views)
I re-checked now and I can confirm we use C module NI9234 and LabVIEW 2014.
So basically I need only to install correct driver for cDAQ-9185 chassis and that is it?
Message 4 of 8
(3,293 Views)
Yes, just install DAQmx 17.1 and everything should work!
Link to download, if you need it: DAQmx Driver
Message 5 of 8
(3,267 Views)
Thank you very much!
And just one more question:
- Can I connect  ICP ACCELEROMETER 352C68 on C module NI9250?
Thank you in advance!
Message 6 of 8
(3,234 Views)
No problem!
Yes, your accelerometer should work with the NI-9250. I suggest reviewing both the NI-9250 specifications and the 352C68 manual to make sure you connect everything properly and are getting the desired data.
NI-9250 Getting Started Guide
NI-9250 Specifications
352C68 Manual
Message 7 of 8
(3,218 Views)
Once again, thank you very much for the support and sorry for taking your time!
I will review it and try to connect it.
Message 8 of 8
(3,185 Views)
