Can USB-6009 digital output (open collector) external pull-up use its on board external +2.5 V output?
I want to config USB-6009 digital output to have +2.5 V as high and 0 V as low digital output. I know I can config USB-6009 digital output to open collector with external pull-up resistor, which can be applied with +2.5 V power source.
My question is: Can I use USB-6009 on board +2.5 V output as the pull-up resistor power source? What resistance is a good number for the pull-up resistor if I can use this configuration?
Thank you very much for the help,
Cathy
(4,525 Views)
Accepted by topic author Cathymin
Hi Cathy,
The USB 6008 digital front end looks like this:
So, there is actually a 4.7 kOhm internal pullup resistor to 5V when the device is configured for open collector.
If you want to output 0-2.5 V, I would look into using a 4.7 kOhm bias resistor between DO and Ground (depending on the rest of your circuit).
Best Regards,
John Passiak
(4,508 Views)
Thank you very much John.
(4,492 Views)
