Can't connect to DAQ NI-9234 with carrier USB-9162 in Ubuntu 20.04
I tried to connect NI9234 with USB9162 in Ubuntu 20.40 (kernel version: 5.15.0-73-generic).
I installed NI daqmx driver following https://www.ni.com/docs/en-US/bundle/ni-platform-on-linux-desktop/page/installing-ni-products-ubuntu... with NI-DAQmx 2023 Q2.
And also installed these packages:
ni-daqmx, ni-hwcfg-utility, ni-syscfg-runtime
The installation didn't show any errors.
But the led light didn't blink.
Run
nilsdev
It didn't show anything.
Run
lsusb
It can see
Bus 001 Device 002: ID 3923:719a National Instruments Corp.
How to fix this issue?
Thanks!
(1,427 Views)
USB-9162 has been replaced by cDAQ-9171. Most likely it is not supported in this Linux DT driver which was released only a few years ago.
https://tmesystems.net/
(1,394 Views)
"Most likely it is not supported in this Linux DT driver which was released only a few years ago."
Where can I find this information?
(1,376 Views)
