Can't use Daq Assistant in Labview 7.1
hi! I have Labview 7.1 installed and an AT-MIO-16E-10 NI board. I can see the board in MAX\devices&Interfaces\traditional NI-DAQ but i can't run any tests(Test panels). I don't know if this is normal for this NI-DAQ model. anyway my main conceirn is that i can not use DAQ Assistant in LabView(when i double click on it or right click->Properties nothing happends). So i can't use my board in LabView. please help! thanks a lot
(2,750 Views)
You can use your board in LabVIEW but you can't use it with DAQmx. In the DAQ Quick Start Guide, the supported devices are listed and the AT E series is only supported with traditional DAQ.
(2,745 Views)
