Can the DAQ display low voltage signal values
Good day,
In my model, I have a strain gauge which has a output voltage in millivolts. I need that data to measure the force.
Can the DAQ display low voltage signal values in the range of millivolts?
I need high accuracy in my results.
(4,095 Views)
You have not mentioned the DAQ device you are using so how can anyone answer your question? Have you read the spore specs? You should be able to answer the question yourself.
(4,092 Views)
Hi Diego,
Look, that question you are asking us depends on the module or board you are using.
In this link: http://sine.ni.com/nips/cds/view/p/lang/en/nid/201987, you can se in the specs which is the minimun voltage range.
I hope this images help you a little bit.
Luis Elias
NI VeriStand and HIL Product Manager
(4,061 Views)
BTW, I forgot to tell you, this specs are for the 6009, you have to search the model you are using!
Luis Elias
(4,060 Views)
Gracias Luis,
De hecho no he comprado un DAQ. La señal del modelo puede ser amplificada; no obstante, necesito el voltage de salida de la galga extensiometrica para calcular la variable que necesito.
Muchas gracias por el comentario.
(4,049 Views)
Que tal Diego,
No tienes nada de que agradecer, sin embargo, si lo que quieres hacer es medir deformaciones con galgas, tenemos un módulo que tiene configuraciones para este tipo de mediciones, es el 9237.
Aquí te dejo un documento relacionado con esto!
https://www.ni.com/en/shop/data-acquisition/sensor-fundamentals/measuring-strain-with-strain-gages.h...
Revisalo, espero que te funcione, ya que las galgas lo que mandan es una señal de variación de Resistencia, entonces con este módulo se coencta a un Puente de Wheatstone.
Saludos,
Luis Elias
(4,047 Views)
Una cosa que olvidé mencionar es que el valor de resistencica de la Galga debe ser de 120 Ohms para ser compatible con el módulo.
Saludos,
Luis Elias
(4,046 Views)
