Can you please help
Hi friends
I am attaching my program . "expected .xls"  is the expected output and "excell.xls"  is the obtained output .
Can you please help me in doing so . I am getting  bulk of 2 D data , but am not able to insert date into each row .
Can you help me in merging the 2 D data and time .
thanking you .
(3,210 Views)
Give something like this a try.  Basically, you need to prepend two tabs to each of your rows except for the first row where you are prepending the date and time.
(3,198 Views)
Thanks for the reply . Can you please mark the blocks with label name and can u send it once again ?
(3,191 Views)
What I posted is called a snippet.  Save the image to your computer.  Then drag the image file onto a block diagram and you will automagically have your code.  Then study it to your heart's content.
(3,185 Views)
Thanks for ur reply . . .:) Will try once and will come back  🙂
(3,183 Views)
