NI USB 6008 how to make power on outputs (DIO) low during startup
Hi all,
Iam working with NI USB 6008 ,i have connected the NIUSB6008 port outputs to relays and LEDs.but when i started my pc then i noticed that the relays starts driving and LEDs blinking.After booting process is over the port outputs are high.Now i want to make low the above said port outputs during the startup of pc that is i dont need any voltage at the output ports (p0.0...)
how can i accomplish it ,please suggest me.
Regards
raghav
Message 1 of 20
(6,674 Views)
Hello Dennis Knutson,
Can you please provide some solution to my question.I think probably nobody has noticed this in USB6008.
Regards
Raghav
Message 2 of 20
(6,661 Views)
Regards
Raghav
Message 3 of 20
(6,661 Views)
Can you please provide some solution to my question.I think probably nobody has noticed this type of problem in USB6008.
Regards
Raghav
Message 4 of 20
(6,660 Views)
Regards
Raghav
Message 5 of 20
(6,661 Views)
The DAQmx C API includes DAQmxSetDigitalPowerUpStates. I don't know if that would solve your problem or not. It night be that you're seeing an initialization routine running, and DAQmxSetDigitalPowerUpStates would only affect the state after initialization was complete.
John Weeks
WaveMetrics, Inc.
Phone (503) 620-3001
Fax (503) 620-6754
www.wavemetrics.com
Message 6 of 20
(6,653 Views)
And all I know about the USB 6008 is what's in the manual:
At system startup and reset, the hardware sets all DIO lines to
high-impedance inputs. The DAQ device does not drive the signal high or
low. Each line has a weak pull-up resistor connected to it.
Message 7 of 20
(6,650 Views)
Right- so the power-up state of the DIO lines is the high-impedance state, and you want it to be set up as an output in the low state. The function I mentioned should do that, if it is supported for the USB 6008. I don't see why it shouldn't be.
If you are using Labview, presumably there is some way to access that information.
Oh, wait- MAX can help here. Go to Devices and Interfaces->NI-DAQmx Devices, find your USB-6008, right-click and select Properties. In the Properties dialog, select the Powerup States tab.
John Weeks
WaveMetrics, Inc.
Fax (503) 620-6754
www.wavemetrics.com
Message 8 of 20
(6,650 Views)
Hi ,
Thanks for your all support.actually i have opened the MAX and selected the devices and interfaces.and i selected the usb and right clicked but i got only save,rename and open visa session but no properties.Where are the properties.
Regards
RAGHAV
Message 9 of 20
(6,632 Views)
Hi ,
Regards
RAGHAV
Message 10 of 20
(6,634 Views)
