Cannot get daq assistant to appear
Hi All,
I am currently using Labview 2009 student edition, I have also installed  NI-DAQmx 8.8, I only have a small project to do with regards acquiring a voltage using a DAQ6008,
I am currently trying this project : http://www.me.umn.edu/courses/me2011/labview/LabVIEW-thermistor.pdf the problem is that DAQ Assistant is nowhere to be seen in my Labview programme.
Is there something I have missed?
I have searched the palette for DAQ and its definately not there.
Any help is appreciated!!
(4,054 Views)
Accepted by Marko1982
Hello Marko,
The issue is that NI-DAQmx 8.8 isn't supported by LabVIEW 2009. You need to download and install DAQmx 8.9.5 or later for LabVIEW 2009 support. I would recommend the newest version of NI-DAQmx:
NI-DAQmx 9.0.2 - Windows 2000/7 x64/7/Vista x64/Vista/XP
Let me know if you run into any further issues.
Dan King
(4,040 Views)
Hi Dan,
Thank you!! That explains a lot! It was getting quite frustrating!Thanks again!
(4,024 Views)
hi all, for some time working with this data card adquisisción as anyone would caused some minor problem, this paper will be able to find some initial advice to start using the DAQ USB6008, I hope they can be useful
https://decibel.ni.com/content/docs/DOC-31767
(3,434 Views)
in this document will be able to find some initial advice to use the USB6008 DAQ Assistant, Greetings
https://decibel.ni.com/content/docs/DOC-31770
(3,433 Views)
Why are you spamming the forums with your link?  Particularly messages that are years old.  Smiley Mad
(3,420 Views)
