Cleaning defective drivers in W2k
Ok, I screw a lot.
I installed LV7.0 on a computer with PC-LPM-16 card and Win98. I installed the NI-DAQ 7.0 and could not use the card. I checked the NI web-site and found that I need to use NI-DAQ 6.9.3.f5. I tried to remove NI-DAQ 7 and install NI-DAQ 6.9.3 , then I found that I need to work under Win2000. I upgraded to w2k and I got a piece of 6.9.3 that is not working, and cannot be uninstalled either.
Can I clean up the drive from the NI-DAQ residues somehow and attempt installing the (LV7 and) NIDAQ 6.9.3f5 again?
Sincerely, Grigor
(2,797 Views)
Hello Grigor,
Thanks for contacting National Instruments. I'm going to attach a file called MSIBlast and instructions on how to use it. This will allow you to delete all National Instruments software and registry keys from your computer. Hopefully this will solve your problem so you can start with a fresh installation of NI-DAQ 6.9.3.
Erick D.
NI Applications Engineer
(2,797 Views)
