I get error code 200324 with my PCI-MIO-16E-1 card
I use Labview 7 and my A/D card was working until last week. Now I hardly find a PCI slot at my PC that the card doesn't crash my PC, and when I do I get this errod code 20034 from the measurement and automation explorer.
I have tried mounting the card at other pci slots, it didn't work.
the services nidevldu and nipxirmu are running - checked.
Any ideas that could help me?
Regards
Christos
(3,282 Views)
Christos,
Aside from the services that you have already checked and they're running, another common cause of this error is needing to reset the DAQ device. After running an example in Traditional NI-DAQ, the board needs to be reset before running an NI-DAQmx example. In MAX, expand Devices and Interfaces. Then right-click on Traditional NI-DAQ Devices and select Reset driver for Traditional NI-DAQ. Hopefully, you will now be able to use the board with NI-DAQmx. Hope this helps. Have a great day!
(3,282 Views)
