Code -200399
I'm having a problem trying to measure voltage. The message that appears in the consoles says:
"It is possible that there was a problem initializing the internal errors database. Please contact National Instruments Technical Support.
Status Code: -200399
DAQmxReadAnalogF64: No extended error information is available for the last error code."
Some of the readings go well, some of them go wrong.
Does anybody have extended information about this error?
Thank you.
Alvaro.
Message 1 of 1
(3,062 Views)
