Function pallett 'Select vi' function missing?
Is there a simply way to re-insert 'Select vi' function in functions pallet short of reinstalling LabView 8.0?  Addittion of PCI ARCnet card in PC caused some temporary problems.  Upon initiating LabView, message popup indicated Activation time out?  This is a professional system, not a run time system.  Why the reactivation?  Anyways, while attempting to reload program developed sometime back in LabView 6.0, when I went to replace a couple of broken vi.s, I noticed I no longer had the option to 'Select vi' in my function pallet.
(3,619 Views)
You will find 'select VI' option at the bottom/last item in the vertical menu list ( after the 'programming' blocks) functions in function palette in LabVIEW 8.0
reg the PCI ARCnet card, sorry i have no answer Smiley Indifferent
(3,611 Views)
Selecting Tools/Advance/Edit pallet allowed me to correct the issue.  Thanks for the feedback.
(3,605 Views)
