Compact DAQ 9215 BNC module -- Error code -200278 occured at DAQmx read
I am trying to read data from a sensor giving an output between +/- 300mv. It is connected to the 9215 BNC module on the Compact DAQ chassis. When i try to acquire any number of samples at any frequency it comes up with an error message at the end (-200278). I have attached the screenshot of the error message.
The program displays information in realtime in a waveform chart on the front panel as the  samples are acquired and also writes them onto a lvm file. I have also attached the vi of the program.
Please help me as i cannot solve this problem. All help will be appreciated.
Harshil
(2,935 Views)
Duplicate Post. See thread:
http://forums.ni.com/ni/board/message?board.id=170&message.id=239082
(2,920 Views)
