Multifunction DAQ
Compact DAQ Set permissions
We have a test system with several different loads. Each load has a Compact DAQ module (with network) to control the IO. When we switch our test system from one load to another we have to set permissions in NI max.
Is there a way to avoid this ? We want to swap loads without setting permissions or can we do that in the software. All compact DAQ modules have the same IP address.
When we want to test a different product we must change the load accordingly and thus the Compat DAQ module.
Best regards
Tonnie
(659 Views)
Reserving a CompactDAQ Ethernet Chassis from LabVIEW
https://tmesystems.net/
(622 Views)
Hello
Thanks for the update
Only problem is that we don't use LabView or CVI.
Our programm is written in C# DotNet.
Do you have suggestion for DotNet as well ?
Thanks in advance
(611 Views)
There must be an equivalent method in DAQmx .NET dll of Reserve Network Device since all tech stack implementations of DAQmx is a wrapper of the DAQmx C DLL.
Santhosh
Soliton Technologies
(604 Views)
Accepted by Tonnie
@Tonnie wrote:
Hello
Thanks in advance
See example in Reconnect Ethernet DAQ Automatically During Data Acquisition Process
(599 Views)
