Comparator, D flip-flop
Hello everyone,
I'm new to LabVIEW and have been working on a project for months to capture the switching behavior of a MOSFET half-bridge circuit. The test bench should run fully automated. This means that when the program is started and the start button is pressed, it should conduct multiple measurements and compare them. Ultimately, it should display which measurements are good or bad, or whether they are above or below the set limits.
I've built a box myself, containing a comparator, a D flip-flop, and a 3-to-8 multiplexer (see image (Box sketch) below). I'm having difficulty writing a program for this box. I've already created a program, but my supervisor doesn't want any manual intervention via a button. It should run fully automatically.
I have below the FlipFlop program to be corrected and my main program as it should look.
Could anyone help me correct my program so that it automatically queries at each run or that no manual selection is required? I would appreciate any help.
I use LabView version 2018.
Message 1 of 1
(1,314 Views)
