08-12-2008 10:32 PM
08-13-2008 08:29 AM
Dear Dougcl,
What you presumed sounds right. The driver is important in this case; the 6023E and the 6024E must be supported by the same DAQmx driver, this shouldn't be a problem since they were introduced at the same time. You can verify this in the Help file from the Measurement And Automation Explorer; contens > installed products > NI DAQ > MAX help for NIDAQmx > NIDAQmx Device terminals > DAQ Devices
If you are using one of the later versions of MAX you can simmulate a 6024E card, just to try this out. Please be sure you are using the same device name.
Best regards
