How do I connect CtrOutO to PFI7 on USB-6221?
When I try to route DevX/ctr0 to PFI7, using property "CO.Pulse.Term", I get the following message "Error -89137 occurred at DAQmx Start Task.vi:1"
I am using the example "Gen Dig Pulse Train-Continous.vi" and I added the use of the above property by changing the "DAQmx Create Channel".
The documentation states ;
"The following table lists the output terminals for counter output. You can use a different PFI line for any of the output terminals.
Ctr0Ctr1
PFI 12PFI 13
How do I do it?
Please refer to the example "Gen Dig Pulse Train-Continous.vi"!
(2,792 Views)
Hello Elinas,
I tried your example and I wasn't able to reproduce your problem. I used DAQmx 8.7.2, I attatched the example which I adjust. I hope this will help you further, please let me know if there are any problems with the example.
Martijn
Message Edited by ninlmartijn on 08-13-2008 07:02 AM
Martijn S
NI Netherlands
(2,790 Views)
