Compiling NIDAQ C codes in DEV C
I recently purchased a NI USB 6008 and was trying to run the  example C code for voltage sampling (\NI-DAQ\Examples\DAQmx ANSI C\Analog In\Measure Voltage\Acq-Int Clk) in Dev C++. However I got a lot of  'undefined reference' errors. I kept the NIdaqmx.h and NIdaqmx.lib in the include and library directory of the compiler but it did not improve anything. I looked into couple of  discussions in the forum about this problem but could not found a straight forward solution . It will be great if someone can point out a solution to tackle the problem.
Message 1 of 14
(6,290 Views)
Have you gone into your compiler’s options and explicitly pointed it toward the include folder? There’s some information on how to do this outlined in the document linked below. The steps refer to a different version of the NI-DAQ drivers, but the overall process is similar.
http://ae.natinst.com/public.nsf/web/searchinternal/b96d51c3f8c32f0986256f040077a386?OpenDocument
Message 2 of 14
(6,266 Views)
I copy pasted the NIDaqmx.h into the include folder of dev C++ and also did the same for the NIDaqmx.lib ( into the library folder of Dev C++). It did not work. However I could not open the link you send me. Thanks for your response though. It would be great if you send an active /valid link.
Message 3 of 14
(6,262 Views)
My apologies. The correct document is linked below.
http://digital.ni.com/public.nsf/allkb/B96D51C3F8C32F0986256F040077A386?OpenDocument
Message 4 of 14
(6,260 Views)
How can I obtain nidex32.lib  and nidaqex.h. This two files were not included in the package. I am not sure if I can download them from NI website. Thanks
Message 5 of 14
(6,258 Views)
nidex32.lib and nidaqex.h are part of the other NI-DAQ driver I mentioned earlier. In your case, those files would be nidaqmx.lib an nidaqmx.h, respectively.
Message 6 of 14
(6,248 Views)
Can you post some of the errors, along with some of the corresponding source code? That will tell if the problem is referencing the header file or the library file.
Message 7 of 14
(6,244 Views)
Here is the compiler error, the code is listed after the error log below.
Compiler: Default compiler
Building Makefile: "C:\Dev-Cpp\Makefile.win"
Executing make...
make.exe -f "C:\Dev-Cpp\Makefile.win" all
gcc.exe -c "../Users/Public/Documents/National Instruments/NI-DAQ/Examples/DAQmx ANSI C/Analog In/Measure Voltage/Acq-Int Clk/Acq-IntClk.c" -o "../Users/Public/Documents/National Instruments/NI-DAQ/Examples/DAQmx ANSI C/Analog In/Measure Voltage/Acq-Int Clk/Acq-IntClk.o" -I"C:/Dev-Cpp/include" -I"C:/Program Files/National Instruments/NI-DAQ/DAQmx ANSI C Dev/include" -I"C:/Program Files/National Instruments/Shared/ExternalCompilerSupport/C/include" -I"C:/Program Files/National Instruments/NI-DAQ/DAQmx ANSI C Dev/include" -ansi -traditional-cpp
../Users/Public/Documents/National Instruments/NI-DAQ/Examples/DAQmx ANSI C/Analog In/Measure Voltage/Acq-Int Clk/Acq-IntClk.c: In function `main':
../Users/Public/Documents/National Instruments/NI-DAQ/Examples/DAQmx ANSI C/Analog In/Measure Voltage/Acq-Int Clk/Acq-IntClk.c:51: error: `int32' undeclared (first use in this function)
../Users/Public/Documents/National Instruments/NI-DAQ/Examples/DAQmx ANSI C/Analog In/Measure Voltage/Acq-Int Clk/Acq-IntClk.c:51: error: (Each undeclared identifier is reported only once
here is the code
#include <stdio.h>
#include <NIDAQmx.h>
#define DAQmxErrChk(functionCall) if( DAQmxFailed(error=(functionCall)) ) goto Error; else
int main(void)
int32 error=0;
TaskHandle taskHandle=0;
int32 read;
float64 data[1000];
char errBuff[2048]={'\0'};
// DAQmx Configure Code
DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
DAQmxErrChk (DAQmxCreateAIVoltageChan(taskHandle,"Dev1/ai0","",DAQmx_Val_Cfg_Default,-10.0,10.0,DAQmx_Val_Volts,NULL));
DAQmxErrChk (DAQmxCfgSampClkTiming(taskHandle,"",10000.0,DAQmx_Val_Rising,DAQmx_Val_FiniteSamps,1000));
// DAQmx Start Code
DAQmxErrChk (DAQmxStartTask(taskHandle));
// DAQmx Read Code
DAQmxErrChk (DAQmxReadAnalogF64(taskHandle,1000,10.0,DAQmx_Val_GroupByChannel,data,1000,&read,NULL));
printf("Acquired %d points\n",read);
Error:
if( DAQmxFailed(error) )
DAQmxGetExtendedErrorInfo(errBuff,2048);
if( taskHandle!=0 ) {
// DAQmx Stop Code
DAQmxStopTask(taskHandle);
DAQmxClearTask(taskHandle);
printf("DAQmx Error: %s\n",errBuff);
printf("End of program, press Enter key to quit\n");
getchar();
return 0;
Message 8 of 14
(6,240 Views)
It looks like there is something wrong with including <NIDAQmx.h>. The error you get is with the definition of int32. That is a DAQmx typedef. Normally gcc should complain if it cannot find the include file, so maybe you are getting a broken version of NIDAQmx.h from somewhere else. Maybe a different file got renamed as NIDAQmx.h and is hiding the correct one.
I would try with a very small test file. Try something like this:
int main(void)
    int32       error=0;
    return 0;
If that works, add additional lines.
You can also tell gcc to dump the preprocessor output. If you do that, you should see the contents of NIDAQmx.h in that output. If not, something is wrong.
Message 9 of 14
(6,229 Views)
I tried to run the code...below are the errors..it seems the problem is with the header file
________________________
Executing gcc.exe...
gcc.exe "C:\Users\samik\Documents\c_practice\test.c" -o "C:\Users\samik\Documents\c_practice\test.exe" -ansi -traditional-cpp -I"C:\Dev-Cpp\include" -I"C:\Program Files\National Instruments\NI-DAQ\DAQmx ANSI C Dev\include" -I"C:\Program Files\National Instruments\Shared\ExternalCompilerSupport\C\include" -L"C:\Dev-Cpp\lib" -L"C:\Program Files\National Instruments\NI-DAQ\DAQmx ANSI C Dev\lib\msvc" -L"C:\Program Files\National Instruments\Shared\ExternalCompilerSupport\C\lib32\msvc"
In file included from C:\Users\samik\Documents\c_practice\test.c:1:
C:/Dev-Cpp/include/NIDAQmx.h:8064: warning: extra tokens at end of #endif directive
C:/Dev-Cpp/include/NIDAQmx.h:39: error: syntax error before '/' token
C:/Dev-Cpp/include/NIDAQmx.h:77: error: syntax error before "int64"
C:/Dev-Cpp/include/NIDAQmx.h:77: warning: data definition has no type or storage class
C:/Dev-Cpp/include/NIDAQmx.h:85: error: syntax error before "uInt64"
C:/Dev-Cpp/include/NIDAQmx.h:85: warning: data definition has no type or storage class
C:/Dev-Cpp/include/NIDAQmx.h:95: error: syntax error at '#' token
C:/Dev-Cpp/include/NIDAQmx.h:95: error: syntax error before "TRUE"
C:/Dev-Cpp/include/NIDAQmx.h:98: error: syntax error at '#' token
C:/Dev-Cpp/include/NIDAQmx.h:101: error: syntax error at '#' token
C:/Dev-Cpp/include/NIDAQmx.h:2155: error: syntax error before '/' token
C:/Dev-Cpp/include/NIDAQmx.h:2224: error: syntax error before '/' token
C:/Dev-Cpp/include/NIDAQmx.h:2287: error: syntax error before '/' token
C:/Dev-Cpp/include/NIDAQmx.h:2295: error: syntax error before "uInt64"
C:/Dev-Cpp/include/NIDAQmx.h:2425: error: syntax error before '/' token
C:/Dev-Cpp/include/NIDAQmx.h:2476: error: syntax error before '/' token
C:/Dev-Cpp/include/NIDAQmx.h:2655: error: syntax error before '/' token
C:/Dev-Cpp/include/NIDAQmx.h:2749: error: syntax error before '/' token
C:/Dev-Cpp/include/NIDAQmx.h:2882: error: syntax error before '/' token
C:/Dev-Cpp/include/NIDAQmx.h:2934: error: syntax error before '/' token
Execution terminated
Message 10 of 14
(6,224 Views)
