Configurate PT 100 in LabView 7.1
I would like to know, how i configurate a termorresistance (PT100) in diagram Block?
I have USB 6008 Data Aquisition Hardware and is it possible to configurate the monitoring in this hardware?
Thank you,
Murilo Malta Valle
(3,361 Views)
To make the connection, if you have the RTD has 2 (look channel which is represented by pins of the board) and see if the board has compatiblidade with its RTD, if the RTD has 3 wire, you must purchase a specific module for him.
(3,343 Views)
