Multifunction DAQ
Configuring baudrate while working with NI-DAQmx
Hello all,
I tried every possible option in property nodes of DAQmx to give a configurable baudrate and finally failed to change the baudrate. Is there a possibilty to change it (like in VISA) ???
(3,570 Views)
Accepted by venky_Sam
DAQmx is a driver for data acquisition devices.  As such it does not have a baud rate associated with it.
VISA is the driver to use with communications devices including RS-232 where baud rate is a parameter.
So what are you actually trying to do?
Lynn
(3,568 Views)
Thanks for the reply Lynn.. Actually I wanted to have 5 times baudrate for my UART communication, and now I know where I was making a mistake.
(3,554 Views)
